What's the Maximum quantity of tiles in a dashboard? (Dynatrace)
Hi, I want to know if there’s a limit of tiles in a dashboard.
Danny Garcia
Hello!
I’m not sure if there’s an exact limit, though I do know that the more tiles you put on a dashboard the longer it may take to load. I personally have a few dashboards with more than 40 tiles.
Kind regards,
Joshua P.
Limit - if exsist - is very high. From my experience I would say big amount of tiles can slightly impact on server performance.
Just like coulleage wrote above, I have many dashboards with 50 or more tiles.
Radek
Dynatrace is reporting when you are over 20 tiles that it can affect performance but for now I didn’t face any radical linit
hello Joshua. Thanks for the support
hey Radoslaw. Thanks for the support
Hey Sebastian. Thanks for the support
Hi Danny! Currently, there is no limit for tiles on a dashboard but that is subject to change. We’ll eventually have a smart limit, which will factor in each tile’s type and configuration.
