Dashboard Metric Explorer
I can not longer add SQL metrics to my dashboard.  Despite giving me the metric or using one in user on another dashboard it says doesnt exist:
“errorType”: “FIELD_DOES_NOT_EXIST”,
“errorMessage”: “The field `avg(sql-server.buffers.cacheHitRatio)` doesn’t exist.”,
Can you show a Data Explorer screenshot?
Best regards
what information do you require, just the list of SQL
Explore Metrics produces this (not working):
timeseries avg(`sql-server.general.userConnections`), by: { `dt.entity.sql:sql_server_instance` }
| fieldsAdd value.A = arrayAvg(`avg(sql-server.general.userConnections)`)
| limit 20
SQL Server overview uses(working):
timeseries
connections = avg(`sql-server.general.userConnections`),
by: {`dt.entity.sql:sql_server_instance`}
| sort arrayAvg(connections) desc
| fieldsAdd entityName(`dt.entity.sql:sql_server_instance`)
| limit 20
Just one metric coming by extension. My point is if you are getting datapoints for some metric by extension.
Best regards
Please raise a support ticket. I’ve encountered similar issues and managed to find a workaround by accessing the classic data explorer, querying the metric, and then opening it in DQL.
