First of all could you please check the support archives regarding the this extension log. If it is an AG extension then the AG support archive or if it is a local version then the MQ SQL server support archive. If during the log review you will not find anything the open a support case.
Thanks @PacoPorro@Mizső I have checked the ActiveGate Log iles and I have realized the issue could have been as a result of the Permissions assigned to the User according to documentation. See below error and documentation
