Dashboard w/Metrics from Multiple Environments
We use Dynatrace Managed at my company.  I would like to know if it is possible to have a dashboard that shows metrics that are collected in different Environments.
Hi @JT
It is possible. Check this link: Create remote/multi-environment Dynatrace dashboards - Dynatrace Docs
I love this feature and I regularly use it.
I hope it helps.
Best regards,
Mizső
Ah   so I see that at the tile level..  awesome.  Thanks.
JT
Although I have access to 10 environments I only see two options to select a remote environment.  What makes some environments visible and other not?  Thanks  JT
Disregard.  I see where to connect remote environments under Settings / Integration.  Thanks  JT
I’m trying to connect a remote environment but not having success with the tokens I have generated.  What specific type of token is needed?  Thanks  JT
Hey JT.  The answer is API V2 scopes.  Thanks  JT
This refers to classic dashboards. I wonder is this also possible with new dashboards? If so, how?
@Enrico_F sure! already documented for a while Remote environment data — Dynatrace Docs
Unfortunately not as easy as with classic, but better than nothing :grinning_face:
