Metrics in different environments
Dynatrace allows you to integrate metrics from remote environments into a dashboard, but you cannot obtain a joint metric and alert about the sum of their values. For example, obtaining in a metric the sum of the HostUnits of two different environments
@jmmatia1 you are correct. Reason being is that the metrics reside in their given tenants. For example If you have EasyTravel and NotSoEasyTravel, Alerts will be defined at each tenant level. If you make a Single Pane of Glass/Communal dashboard, its only ingesting the values in, and not formulating as a metric per say in the dashboarded environment. The function only allows you to see data across tenants but the power of alerting would always reside in the metric origin tenant.
