When trying to export a graph from the data explorer in CSV format, I only get 3 empty columns (metricId, time and value).
I don’t want to export the static CSV file because I would like to refresh it from Excel directly. With JSON format, I am having problems getting the graph.
Is there a way to get the CSV file in Excel and be able to update it from there directly?
Thanks in advance!
Hi Elena,
Maybe this can be helpful.
Best regards
Hi Anton,
No, I added the Api Token like that and it doesn’t give me any errors. But the result is not the data for the graph.
Regards.
Hi @elenaperez
Yes, it’s possible to export data and refresh directly in Excel.
1.- Define your query of Data Explorer.
2.- Use the API to execute the metric selector: https://{environmentid}.live.dynatrace.com/api/v2/metrics .( Metrics API - GET metrics — Dynatrace Docs)
3.- Connect the API in Excel with PowerQuery
With this way you can execute the Metric Selector in Dynatrace API, connect with excel and refresh data
I hope it’s helful
