Good mroning,
I see the DT documentation and make a understanding of ‘Default transformation’ (Metrics API - Metric selector — Dynatrace Docs), but I still have a question about the default(0) like below:
Same Metric except default(0):
1. without default (0) - builtin:billing.ddu.metrics.total:splitBy():sum:auto:sort(value(avg,descending))
2. with default (0) - builtin:billing.ddu.metrics.total:splitBy():sum:auto:sort(value(avg,descending)):default(0,always)
3. Compare with UI
I just want to aviod the no data situation and used default() in query, Why is there a diff in the result?Should I use it?
