Hi, Everyone,
Hope you are doing well.
I find there is a new column I could use in data explorer, which is “Default”
in the doc, it said I could “Set Default to the desired default value.”
and with the screenshot I shared, I have two same metrics and the only different setting is on the Default column.
I’m a bit confused is this setting would just fill up a number I set in the Default column with the time between14:47~14:52(red part)? or are there any more use cases with this setting?
I’m not sure did I use "the default setting "in the right way, but I think if it just fills up a value I set in the metric/dashboard, it might be a bit strange for me
so I wanna check is there any more useful use cases that doc didny mentioned or I could take advantage of. thank you ![]()
FYI, the advanced mode query are
builtin:cloud.azure.appService.traffic.requests:splitBy():count:sort(value(avg,descending)):limit(1):default(50.0):timeshift(0d)
and
builtin:cloud.azure.appService.traffic.requests:splitBy():count:sort(value(avg,descending)):limit(1):timeshift(0d)
Thanks in advance
