Hi Dynatrace Community,
We are observing a significant difference in the Host Availability % between Data Explorer and the Host Overview page for some AIX servers.
Environment
- OS: AIX
- Hosts: UPI DB1 / UPI DB2
- Time period: September
- Dynatrace: Managed environment
Issue
When we check the availability for the same hosts and the same time period:
- Data Explorer: Host Availability is showing approximately 35.3%
- Host Overview: Host Availability is showing approximately 99%
This is a significant difference, even though we are checking the same hosts and September time period.
What we would like to understand
Could someone please clarify:
- What is the exact metric/key and calculation used by the Host Overview page to calculate Host Availability %?
- Is the availability shown in Data Explorer calculated differently from the Host Overview page?
- Could this difference be related to:
- Metric aggregation
- Availability event calculation
- Timeframe/timezone
- Host monitoring state
- Missing telemetry/data points
- AIX-specific monitoring behavior
- Which value should be considered the correct Host Availability % for monthly reporting/SLA purposes?
We would also appreciate it if someone could provide the recommended metric selector/DQL query to reproduce the same availability percentage shown on the Host Overview page.
I can share screenshots, the Data Explorer configuration/metric selector, host details, and the exact timeframe if required.
Thanks in advance for your help.
Host availabilityAIX.docx (531 KB)
Hi @Sohel_Rashid
This is a well-known discrepancy in Dynatrace. Let me answer your question one by one
- 1. What is the exact metric/key and calculation used by the Host Overview page to calculate Host Availability %?
- The Host Overview page does not use a raw timeseries metric for its availability display. it calculates availability based on problem/availability events recorded against the host entity. This tends to produce high availability numbers (~99%) because it only counts explicit DOWN events.
- 2. Is the availability shown in Data Explorer calculated differently from the Host Overview page?
- Yes, It uses the dt.host.availability timeseries metric, which is reported every minute based on OneAgent heartbeat state. If OneAgent is not actively sending data (any non-UP state), those minutes count as unavailable.
- 3. Could this difference be related to:
- Metric aggregation - Yes, partially. If you use avg instead of max(rollup: sum) in Data Explorer, results will be skewed. The correct aggregation for availability % is max with rollup: sum, then normalize against interval length.
- Availability event calculation - Yes, this is the primary cause.
- Timeframe/timezone - Possible but I have to check this point separately :slightly_smiling_face:
- Host monitoring state - Yes, significant contributor
- Missing telemetry/data points - Yes, directly causes the gap. Every minute where no heartbeat is received registers as a non-UP data point. A 35% availability figure means maximum number of minutes were non-UP — this points to a persistent agent issue, not just occasional gaps.
- AIX-specific monitoring behavior - Yes, AIX is a known factor. AIX OneAgent has historically had more telemetry interruptions compared to Linux/Windows
- 4. Which value should be considered the correct Host Availability % for monthly reporting/SLA purposes? It depends on how your SLA is defined but the metric-based (Data Explorer) value is more rigorous.
Example:
If SLA like “Host was not in a detected DOWN/problem state” then use Host Overview (~99%)
If SLA like “OneAgent was actively monitoring and reporting every minute” then use Data Explorer (~35%)
Sujit
