Database Insights: Oracle
Hi all.
We have activated the Oracle EAP plugin in our managed environment.
Where can I see the use of tablespace? Can I create an alarm for the use of tablespace?
Can I alarm if the bdd is down?
thanks in advanced.
Jose A
All available metrics you will be able to see in Custom Network device created for your DB (if you don’t have agent on Oracle host) or on Oracle process card (if you have agent installed there). You have to click though tabs with metrics. I don’t see tablespace there listed but it seems to be captured as custom metric:
You can go to settings, Anomaly detection, create custom event for alerting and define alert there for tablespace. I don’t see any metric related to BDD, but check this list, maybe you will find something. I’m not Oracle engine expert :slightly_smiling_face:
Thanks Sebastian!!
