when a Event or problem workflow is triggered, I you try to do a dql query to retrieve the attached problem or events resp. It seems these are not yet available.
After sometime when you run the workflow again retrieving the events attached to a problem and retrieving the problem attached to an event gives no issue;s.
Who knows the wait time before Davis has added these records to a bucket, after a trigger?
KR Henk
It should only take 10 seconds from Workflow being triggered by an Event (this is done internally), to the Event appearing in Grail.
I would recommend adding a Run JavaScript step with
export default async function ({ execution_id }) {
console.log('Starting to sleep');
const milliseconds = 15000; // sleep time
await new Promise(resolve => setTimeout(resolve, milliseconds));
console.log('Done sleeping');
before the actual DQL statement.
In addition, a built-in “delay” feature for Workflows is planned.
Hi Christian,
FYI this is how my WF looks (-; creating the 5 mins delay!
I will retry to skip the two delay scripts and limit the wait in the main part see what happens. (also I will use the Promise , great reminder)
Again thanks for your help!
Hi Christian,
Very small remark/question: I assume all workflow task are separated, I mean the next step will only start if the previous is finished?
KR Henk
Looking at your screenshot, those tasks should be running in sequence, not parallel.
However, within a single JavaScript task, some things can run parallel, for instance:
console.log('Starting...');
setTimeout(() => { console.log('First'); }, 1000);
setTimeout(() => { console.log('Second'); }, 500);
console.log('Done!');
This code sample will lead to an unexpected output of
Starting...
Done!
Second
First
you need to use await and a promise to make it right here:
await new Promise(resolve => setTimeout(() => { console.log('First'); resolve(); }, 1000));
await new Promise(resolve => setTimeout(() => { console.log('Second'); resolve(); }, 500));
and you will get the expected output of Starting…, First, Second and Done.
FYI: we just added another task option to make a task wait a user defined time before executing..This will become available in the upcoming weeks and should make this a lot easier.
