Data freshness for events and problems
Who can confirm below?
When using a “event” or “problem” trigger in a workflow, why does it take 5 minutes for you can retrieve by DQL:
Events belonging to a Problem
Problem belonging to an Event
For my workflow needed to wait 3x 1:59 minutes to make it work (timeout per task is 2:00 min)k
KR Henk
there is a slight delay between when Workflows are triggered (by an event), and when data is available in Grail to be fetched.
Though I’ve never seen a delay above 30 seconds. Could you share the DQL Statements that you’re using to fetch those events / problems? Are you using the DQL Action, or writing JavaScript Code?
Hello Christian,
This is the trigger:
Sending you the top/important part of the JS task:
import { execution } from ‘@dynatrace-sdk/automation-utils’;import { queryExecutionClient } from ‘@dynatrace-sdk/client-query’;import { eventsClient } from “@dynatrace-sdk/client-classic-environment-v2”;//Before this task already 2 tasks have been active with the same delaysetTimeout(() => {  console.log(“1 minute has passed”);}, 119000);
export default async function ({ execution_id }) {    try {        // Get the current execution        const ex = await execution(execution_id);
        // Extract event data        const data = ex.event();        const url = “https :// events.pagerduty.com/v2/enqueue”;
        // Initialize payload and custom_details if not present        data.payload = data.payload || {};        data.payload.custom_details = data.payload.custom_details || {};
        const eventIds = data[‘dt.davis.event_ids’];        let allTags = {};
        // Fetch event details and add them directly to custom_details        try {            for (const eventId of eventIds) {                const eventQuery = `fetch dt.davis.events |  filter event.id == “${eventId}”`;                //console.log(“**********”,eventQuery);                const eventResponse = await queryExecutionClient.queryExecute({                    body: {                        query: eventQuery,                        requestTimeoutMilliseconds: 60000,                        fetchTimeoutSeconds: 60000                    }                });Retrieving the events will fail if if you do not wait for min 5 minutes.(can share full script but than I need to sanitize first (-;)KR Henk
A wait time of 10 seconds (let’s make it 15 seconds to be on the safe side) should be enough. In your code example, I believe you’re missing the await statement.
  console.log('Starting to sleep');
  const milliseconds = 15000; // sleep time
  await new Promise(resolve => setTimeout(resolve, milliseconds));
  console.log('Done sleeping');
Can you verify that the execution of the step that should sleep takes the expected amount of time, e.g., 15 seconds as in my example?
Hello Christian,
This will make your day, I have now a 20s wait,
No problems!
Thanks for you help and guidance!
KR Henk
