Retrieve problems via DQL
Just a quick tip that you can retrieve problems via DQL:
Here I’m filtering for problems that have been created in the last 30mins which contain `Critical Redis connection error!` in the title.
fetch events, from: now()-30m, to: now()<br>| filter event.kind == "DAVIS_PROBLEM"<br>| filter event.status_transition == "CREATED"<br>| filter matchesPhrase(event.name, "Critical Redis connection error!")
you can also do this in workflow tasks:
import { queryExecutionClient } from "@dynatrace-sdk/client-query";
const data = await queryExecutionClient.queryExecute({
  body: {
  query: 'fetch events, from: now()-30m, to: now() | filter event.kind == "DAVIS_PROBLEM" | filter event.status_transition == "CREATED" | filter matchesPhrase(event.name, "Critical Redis connection error!")',
