@FranciscoGarcia
That’s not it… I have my dashboard using these double quotes and the Parse is done correctly. What is happening is that in the code below, at times, especially when I increase the period in the timeframe, for example 24h, 6 hours, Dynatrace returns events with OPEN status when in reality they are no longer open. I’m trying to adjust this. I need Dynatrace to return only open problems, get the last event.
fetch events
| filter event.kind == "DAVIS_PROBLEM"
| fieldsAdd entity_tags
| expand entity_tags
| parse entity_tags, """ "Jornada:" DATA:Jornada """
| parse entity_tags, """ "Serviço Negócio:" DATA:ServicoNegocio """
| parse entity_tags, """ "Canal:" DATA:Canal """
| parse entity_tags, """ "Etapa:" DATA:Etapa """
| parse entity_tags, """ "Fluxo:" DATA:Fluxo """
| fieldsAdd affected_entity_types
//| fieldsAdd dt.entity.queue.name, dt.entity.queue
//=============== Lookup for affected_entity_ids and root_cause_entity_id Start ===============
| expand affected_entity_ids
| expand root_cause_entity_id
| lookup [fetch dt.entity.service], sourceField:affected_entity_ids, lookupField: id, prefix:"lookup.affected.entity.services"
| lookup [fetch dt.entity.service], sourceField:root_cause_entity_id, lookupField: id, prefix:"lookup.rootcause.entity.services"
| lookup [fetch dt.entity.queue], sourceField:affected_entity_ids, lookupField: id, prefix:"lookup.affected.entity.queue"
| lookup [fetch dt.entity.service_method], sourceField:affected_entity_ids, lookupField: id, prefix:"lookup.affected.entity.service_method"
| lookup [fetch dt.entity.process_group_instance], sourceField:affected_entity_ids, lookupField: id, prefix:"lookup.affected.entity.pgi"
| lookup [fetch dt.entity.process_group_instance], sourceField:root_cause_entity_id, lookupField: id, prefix:"lookup.rootcause.entity.pgi"
| lookup [fetch dt.entity.application], sourceField:affected_entity_ids, lookupField: id, prefix:"lookup.affected.entity.applications"
| lookup [fetch dt.entity.application], sourceField:root_cause_entity_id, lookupField: id, prefix:"lookup.rootcause.entity.applications"
| lookup [fetch dt.entity.mobile_application], sourceField:affected_entity_ids, lookupField: id, prefix:"lookup.affected.entity.mobile"
| lookup [fetch dt.entity.mobile_application], sourceField:root_cause_entity_id, lookupField: id, prefix:"lookup.rootcause.entity.mobile"
| lookup [fetch dt.entity.custom_application], sourceField:affected_entity_ids, lookupField: id, prefix:"lookup.affected.entity.customapplication"
| lookup [fetch dt.entity.custom_application], sourceField:root_cause_entity_id, lookupField: id, prefix:"lookup.rootcause.entity.customapplication"
| lookup [fetch dt.entity.cloud_application], sourceField:affected_entity_ids, lookupField: id, prefix:"lookup.affected.entity.cloudapplication"
| lookup [fetch dt.entity.cloud_application], sourceField:root_cause_entity_id, lookupField: id, prefix:"lookup.rootcause.entity.cloudapplication"
| lookup [fetch dt.entity.synthetic_test], sourceField:affected_entity_ids, lookupField: id, prefix:"lookup.affected.entity.synthetictest"
| lookup [fetch dt.entity.synthetic_test], sourceField:root_cause_entity_id, lookupField: id, prefix:"lookup.rootcause.entity.synthetictest"
| lookup [fetch dt.entity.http_check], sourceField:affected_entity_ids, lookupField: id, prefix:"lookup.affected.entity.httpcheck"
| lookup [fetch dt.entity.http_check], sourceField:root_cause_entity_id, lookupField: id, prefix:"lookup.rootcause.entity.httpcheck"
| lookup [fetch dt.entity.kubernetes_cluster], sourceField:affected_entity_ids, lookupField: id, prefix:"lookup.affected.entity.kubernetescluster"
| lookup [fetch dt.entity.kubernetes_cluster], sourceField:root_cause_entity_id, lookupField: id, prefix:"lookup.rootcause.entity.kubernetescluster"
| lookup [fetch dt.entity.host], sourceField:affected_entity_ids, lookupField: id, prefix:"lookup.affected.entity.hosts"
| lookup [fetch dt.entity.host], sourceField:root_cause_entity_id, lookupField: id, prefix:"lookup.rootcause.entity.hosts"
| lookup [fetch dt.entity.custom_device], sourceField:affected_entity_ids, lookupField: id, prefix:"lookup.affected.entity.customdevices"
| lookup [fetch dt.entity.custom_device], sourceField:root_cause_entity_id, lookupField: id, prefix:"lookup.rootcause.entity.customdevices"
| lookup [fetch dt.entity.hypervisor], sourceField:affected_entity_ids, lookupField: id, prefix:"lookup.affected.entity.hypervisor"
| lookup [fetch dt.entity.hypervisor], sourceField:root_cause_entity_id, lookupField: id, prefix:"lookup.rootcause.entity.hypervisor"
| lookup [fetch dt.entity.environment], sourceField:affected_entity_ids, lookupField: id, prefix:"lookup.affected.entity.environment"
//=============== Lookup for affected_entity_ids and root_cause_entity_id End ===============
| summarize {startTime = takeMax(event.start),
endTime = takeMax(event.end),
Duration = takeMax(resolved_problem_duration),
Status = takeMax(event.status),
event.name = takeMax(event.name),
severityLevel = takeFirst(event.category),
Recorrencia = countDistinct(dt.davis.last_reopen_timestamp),
UltimaReabertura = takeFirst(dt.davis.last_reopen_timestamp),
dt.davis.is_duplicate = takeMax(dt.davis.is_duplicate),
Jornada = takeLast(Jornada),
ServicoNegocio = takeLast(ServicoNegocio),
Canal = takeLast(Canal),
Fluxo = collectDistinct(Fluxo),
Etapas = collectDistinct(Etapa),
TipoEntidade = takeFirst(affected_entity_types),
affected = collectDistinct(affected_entity_ids),
rootCause = takeFirst(root_cause_entity_id),
affectedServices = collectDistinct(lookup.affected.entity.servicesentity.name),
affectedQueues = collectDistinct(lookup.affected.entity.queueentity.name),
affectedMethod = collectDistinct(lookup.affected.entity.service_methodentity.name),
affectedPGI = collectDistinct(lookup.affected.entity.pgientity.name),
affectedApplications = collectDistinct(lookup.affected.entity.applicationsentity.name),
affectedMobile = collectDistinct(lookup.affected.entity.mobileentity.name),
affectedCustomApplication = collectDistinct(lookup.affected.entity.customapplicationentity.name),
affectedCloudApplication = collectDistinct(lookup.affected.entity.cloudapplicationentity.name),
affectedSyntheticTest = collectDistinct(lookup.affected.entity.synthetictestentity.name),
affectedHttpCheck = collectDistinct(lookup.affected.entity.httpcheckentity.name),
affectedKubernetesCluster = collectDistinct(lookup.affected.entity.kubernetesclusterentity.name),
affectedHosts = collectDistinct(lookup.affected.entity.hostsentity.name),
affectedCustomDevices = collectDistinct(lookup.affected.entity.customdevicesentity.name),
affectedHypervisor = collectDistinct(lookup.affected.entity.hypervisorentity.name),
affectedEnvironment = collectDistinct(lookup.affected.entity.environmententity.name),
rootCauseServices = collectDistinct(lookup.rootcause.entity.servicesentity.name),
rootCausePGI = collectDistinct(lookup.rootcause.entity.pgientity.name),
rootCauseApplications = collectDistinct(lookup.rootcause.entity.applicationsentity.name),
rootCauseMobile = collectDistinct(lookup.rootcause.entity.mobileentity.name),
rootCauseCustomApplication = collectDistinct(lookup.rootcause.entity.customapplicationentity.name),
rootCauseSyntheticTest = collectDistinct(lookup.rootcause.entity.synthetictestentity.name),
rootCauseHttpCheck = collectDistinct(lookup.rootcause.entity.httpcheckentity.name),
rootCauseHosts = collectDistinct(lookup.rootcause.entity.hostsentity.name),
rootCauseCustomDevices = collectDistinct(lookup.rootcause.entity.customdevicesentity.name),
event.id = takeFirst(event.id)},
by:{display_id}
| filter `dt.davis.is_duplicate` == false
| fieldsAdd currentTime = toTimestamp(now())
| fieldsAdd Status = if((Status == "ACTIVE"),"OPEN",else:if((Status == "CLOSED"), "CLOSED"))
| filter ("ALL" == $Status OR $Status == Status)
| filter ("ALL" == $Severity OR $Severity == severityLevel)
| fields Status = if((Status == "OPEN"),"⭕ OPEN",else:if((Status == "CLOSED"),"✅ CLOSED")),
Problem = (display_id),
StartTime = startTime,EndTime = if((Status == "OPEN"),"In Progress",
else:if((Status == "CLOSED"),endTime)),`Duration (min)` = if((Status == "CLOSED"),Duration,
else:if((Status == "OPEN"), toLong(currentTime-startTime)/60000000000)),
Evento = event.name,
Recorrencia = if((Recorrencia == 0),"Não",else:"Sim"),
//Reaberto = if((Recorrencias == 0),"Não",else:concat("Qtde Reaberturas: ",Recorrencias)),
UltimaReabertura = if(isNull(UltimaReabertura), "Não foi reaberto", else:UltimaReabertura),
Severity = severityLevel,
TipoEntidade,
Affected = arrayRemoveNulls(arrayConcat(affectedMethod,affectedQueues,affectedApplications,affectedMobile,affectedCustomApplication,affectedCloudApplication,affectedSyntheticTest,affectedHttpCheck,affectedServices,affectedPGI,affectedKubernetesCluster,affectedHosts,affectedHypervisor,affectedCustomDevices,affectedEnvironment)),
RootCause = arrayRemoveNulls(arrayConcat(rootCauseCustomDevices,rootCauseHosts,rootCauseHttpCheck,rootCauseServices,rootCausePGI,rootCauseApplications,rootCauseMobile,rootCauseCustomApplication,rootCauseSyntheticTest)),
Jornada,
ServicoNegocio,
Canal,
Fluxo= arrayRemoveNulls(Fluxo),
Etapas,
event.id
| fieldsAdd ServicoNegocio = if(isNull(ServicoNegocio), "Não Definido", else:ServicoNegocio)
| fieldsAdd Jornada = if(isNull(Jornada), "Não Definido", else:Jornada)
| fieldsAdd Fluxo = if(isNull(Fluxo), "Não Definido", else:Fluxo)
| fieldsAdd Etapas = if(isNull(Etapas), "Não Definido", else:Etapas)
| fieldsAdd Canal = if(isNull(Canal), "Não Definido", else:Canal)
| filter in(Canal,array($Canal))
| filter in(ServicoNegocio,array($ServicoNegocio))
| filter ("ALL" == $Jornada OR $Jornada == Jornada)
| filter ("ALL" == $Recorrencia OR $Recorrencia == Recorrencia)
