Deleting a custom metric dimension
Is there a way to delete a custom metric dimension? I’ve accidentally added a incorrect value to the dimension and want to remove it. Do I need to delete the metric itself? Ideally don’t want to lose the data tied to the metric, I just need the dimension removed from the metric.
You can change the dimension value, so you could put in a new dimension and let the metric be calculated for those.
Nevertheless, the dimension name you gave it before, you cannot change. So if you change from the dimension value from {RequestAttribute:A} to {RequestAtrribute:B}, the name of the dimension that you gave before (also what will show up in the data explorer and placeholders) will not adjust. So if you called it Request Attribute A, it will still be called that way.
Settings>Server-Side service monitoring > Calculated service metric
@marina_pollehn already explained it, the dimension keeps the name.
Apologies for not adding more context. The info provided seems to be related specifically to calculated service metrics. What I am working with is a custom 2.0 extension for database queries.
In that case, the dimension lasts as long as there is data related to the specific dimension.
If you change the dimension, it will disappear if the timeframe does not contain the data.
Thank you for the information!
