Hi guys,
Not sure sure if high or low number of percentage is effecting the sensitivity here:
i.e. if we want this anomaly detection rule to be less sensitivity should we put 1% or 99% - can any one helps with explanation?
Yos
Yos,
The lower the values the less chance you’ll get alerted.
Gil.
Don’t know how this question found its way to NAM :facepalm:
@MaciejNeumann can you help an move it to Dynatrace Open Q&A please?
Done 🙂
Hello @gilgi
Need quick understanding on Load drop alerts.
If baseline or expected service load is 100/min and threshold for load drop margin is set to 15% of baseline, then alert will trigger if load is less than 85/min or 15/min?
Mohit
Less than 15.
Gil.
