We have two different types of metrics and we want to showcase “Graph” using data from them.
Objective: Count the number of jobs in a particular job status and show it’s showing a historical time chart
Metric1: JobsInPlanCount
application_wa_JobsInPlanCount_job{jobstatus="ERROR"} 16
application_wa_JobsInPlanCount_job{jobstatus="SUCCESSFUL"} 15
application_wa_JobsInPlanCount_job{jobstatus="RUNNING"} 0
application_wa_JobsInPlanCount_job{jobstatus="SUPPRESS"} 0
application_wa_JobsInPlanCount_job{jobstatus="READY"} 4
application_wa_JobsInPlanCount_job{jobstatus="WAITING"} 10
application_wa_JobsInPlanCount_job{jobstatus="UNDECIDED"} 0
application_wa_JobsInPlanCount_job{jobstatus="HELD"} 0
application_wa_JobsInPlanCount_job{jobstatus="CANCELED"} 0
application_wa_JobsInPlanCount_job{jobstatus="BLOCKED"} 0
Dimension key: “jobstatus” (Only one)
Aggregation: Auto(avg) and Graph.
Result: Correct result was observed even though time duration was varied (2 hrs , 6hrs, 24hrs , 72 hrs , 7 days etc)
Code used is : wa.metric.application_wa_JobsInPlanCount_job:splitBy(jobstatus):sort(value(auto,descending))
Metric2 : JobsByWorkstation
application_wa_JobsByWorkstation_jobs{jobstatus="UNDECIDED",workstation="/MASTERAGENTS"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="HELD",workstation="/WA_SAGT_0"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="HELD",workstation="/WA_SAGT_1"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="SUPPRESS",workstation="/MASTERAGENTS"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="SUCCESSFUL",workstation="/HWA-GKE-SERVE_XA"} 7
application_wa_JobsByWorkstation_jobs{jobstatus="CANCELED",workstation="/WA_SAGT_0"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="CANCELED",workstation="/WA_SAGT_1"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="BLOCKED",workstation="/MASTERAGENTS"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="ERROR",workstation="/HWA-GKE-SERVE_XA"} 1
application_wa_JobsByWorkstation_jobs{jobstatus="WAITING",workstation="/HWA-GKE-SERVE_XA"} 4
application_wa_JobsByWorkstation_jobs{jobstatus="READY",workstation="/WA_SAGT_0"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="READY",workstation="/WA_SAGT_1"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="SUPPRESS",workstation="/HWA-GKE-SERVE_XA"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="UNDECIDED",workstation="/WA_SAGT_1"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="UNDECIDED",workstation="/WA_SAGT_0"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="READY",workstation="/MASTERAGENTS"} 4
application_wa_JobsByWorkstation_jobs{jobstatus="RUNNING",workstation="/MASTERAGENTS"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="WAITING",workstation="/MASTERAGENTS"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="SUCCESSFUL",workstation="/MASTERAGENTS"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="BLOCKED",workstation="/HWA-GKE-SERVE_XA"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="BLOCKED",workstation="/WA_SAGT_1"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="BLOCKED",workstation="/WA_SAGT_0"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="ERROR",workstation="/WA_SAGT_0"} 6
application_wa_JobsByWorkstation_jobs{jobstatus="CANCELED",workstation="/HWA-GKE-SERVE_XA"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="ERROR",workstation="/WA_SAGT_1"} 9
application_wa_JobsByWorkstation_jobs{jobstatus="SUCCESSFUL",workstation="/WA_SAGT_1"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="RUNNING",workstation="/HWA-GKE-SERVE_XA"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="HELD",workstation="/HWA-GKE-SERVE_XA"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="SUCCESSFUL",workstation="/WA_SAGT_0"} 8
application_wa_JobsByWorkstation_jobs{jobstatus="WAITING",workstation="/WA_SAGT_1"} 2
application_wa_JobsByWorkstation_jobs{jobstatus="UNDECIDED",workstation="/HWA-GKE-SERVE_XA"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="WAITING",workstation="/WA_SAGT_0"} 4
application_wa_JobsByWorkstation_jobs{jobstatus="RUNNING",workstation="/WA_SAGT_1"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="READY",workstation="/HWA-GKE-SERVE_XA"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="RUNNING",workstation="/WA_SAGT_0"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="HELD",workstation="/MASTERAGENTS"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="CANCELED",workstation="/MASTERAGENTS"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="SUPPRESS",workstation="/WA_SAGT_0"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="SUPPRESS",workstation="/WA_SAGT_1"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="ERROR",workstation="/MASTERAGENTS"} 0
It has two dimenshion keys : “jobstatus” and “workstatus”
Dimension key: “jobstatus” and "workstation (Only two)
Aggregation:
(a) Auto(avg) not working because giving a decimal value for it (which is incorrect).
(b) Sum is giving extrapolated value
- For short duration - giving twice of the actual count or sometimes other value.
- For long duration- With the increase in time duration, its value is linearly increasing.
[ have a look to the attached screenshots ]
Kindly, tell me how to avoid these erroneous results.
Thank You
