Disable Dyntrace Autoupdater for Environment Activegate
Hello:
I would like to disable the Dyntrace Auto-update for an Environment Activegate.
Is there a config setting that can be set via a properties file to make that happen?.
Thank you!
Select ActiveGate you are insterested, and click in “Settings”:
Turn off this flag and saves changes.
This configuration can be done in tenant level to be aplied in all ActiveGates. And you have an API also.
Best regards
Hello @dyn98007
You can disable the AG update via API through :
  • Environment API V2 > ActiveGates - Auto-update configuration > PUT
  • It requires creating access token with “activeGates.write” scope and “AG ID” can be obtained under Manage  >  deployment status > Activegates > pickup the target AG > select the ID and use it the API request.
  • Unlock the key with the generated token > use ID > change the “globalSetting”: “DISBLED” , then execute.
  • Upon successful execution you will see the attached message
    Code Description
    204 Success. The global auto-update configuration have been updated. Response doesn’t have a body.
VIA UI:
  • Manage > Deployment status > Activegates > select the target AG > settings > ActiveGate updates
  • The default option : automatic updates at earliest convenience
  • Switch it Off and save changes.
As described by @AntonPineiro , both methods are applicable based on the current access privileges.
Hoping it adds value.
KR,
Peter
I would strongly advise to leave auto updating on.
Hi @adam_gardner
  • Agree with you it’s recommended to keep the auto update On to keep the component updated with the latest fixes and enhancements.
  • While some customers’ policies prohibit that behavior unless there is approved change request.
KR,
Peter.
