Can we disable dt.trace_id and dt.span_id in logs ( auto-enrichment of log)?
Disable the OneAgent feature for auto-enrichment. You can do this globally, at the process group level, or at the K8S cluster/namespace level. Keep in mind that if you disable this feature, the logs will no longer be linked to the trace.
