Dynatrace OneAgent replace OpenTelemetry Traces
My system has a plugin that uses openTelemetry to monitor my Jenkins runs and I have Dynatrace OneAgent installed. The span generated by openTelemetry is replaced by Dynatrace, it has type: com.dynatrace.agent.introspection.span.opentelemetry.DynatraceCompositeSpan. Is there a way to disable this feature so the span remain untouched?
Jamie
You can disable OneAgent OpenTelemetry features in the OneAgent features setting on the process level. This will disable OpenTelemetry sensors and your OpenTelemetry traces will remain untouched.
