Disk name filter usage in metric event
Hi Team,
Is it possible to use disk name filter while using metric event to monitor disk availability? If yes, using dimension key “dt.entity.disk.name” would help?
Many thanks.
Hi @SrikanthSamraj.
Do you mean disk available metric? if yes, then you can switch the event type to metric selector and the name as well using the below sample and you can change the disk name
builtin:host.disk.avail:filter(and(or(in(“dt.entity.disk”,entitySelector(“type(disk),entityName.equals**(~“C:\~”)**”))))):splitBy(“dt.entity.disk”,“dt.entity.host”):sort(value(auto,descending)):limit(20)
Best Regards,
Mohamed
Thanks @Mohamed_Hamdy .
My query is in line with usage of metric key to monitor disk available percentage for a specific disk or exclude disks (using a negate criteria) in a metric event. I think that’s possible. Attached screen shot of it too.
Is it possible to negate disk name “C:\” using metric selector?
Try this
builtin:host.disk.usedPct:filter(not(in(“dt.entity.disk”,entitySelector(“type(disk),entityName(~“C:\~”)”)))):splitBy(“dt.entity.host”,“dt.entity.disk”):auto:sort(value(avg,descending)):limit(100)
Thanks much @dannemca. It worked like a charm.. I was actually looking for nix systems.. below one helped me to figure out what I can have..
builtin:host.disk.usedPct:filter(and(or(in(“dt.entity.host”,entitySelector(“type(host),tag(~“xxx:xxx~”),tag(~“os:xxxx~”),tag(~“xxx:xxx~”)”))),not(in(“dt.entity.disk”,entitySelector(“type(disk),entityName.in(~”/~“,~”/dev~“,~”/boot~“,~”/boot/efi~“,~”/admin~“,~”/audit~“,~”/home~“,~”/home2~“,~”/mksysbfs~“,~”/opt~“,~”/backup/Config~“,~”/opt/core~“,~”/opt/DoOnceAIX~“,~”/opt/samgr/systemlogs~“,~”/proc~“,~”/sys~“,~”/tmp~“,~”/users~“,~”/usr~“,~”/usr/local/lrs~“,~”/var~“,~”/var/adm/perfmgr~“,~”/var/adm/ras/livedump~“,~”/var/cache/yum~“,~”/var/crash~“,~”/var/log~“,~”/var/log/audit~“,~”/var/perf~“,~”/var/perf/pm~“,~”/var/spool/lpd/qdir~“,~”/var/spool/qdaemon~“,~”/rpool~“,~”/var/cache/dnf~“)”)))))
