How to exclude a specific disk on a single host in a custom metric event?
Hi
I have custom metric event with filtering host multiple conditions for disk event .
i want to exclude one disk for one server.  host abc mountpoint /disk1
builtin:host.disk.usedPct:filter(and(
or(in(“dt.entity.host”,entitySelector(“type(host),osType(~“LINUX~”)”))),
or(not(in(“dt.entity.host”,entitySelector(“type(host),tag(~“team:bx_unix~”)”))))
)):splitBy(“dt.entity.host”,“dt.entity.disk”)
how can i achieve that . one way is to tag disk and exclude disk in filter .
but how can i separate in metric key  .   i can filter via tag but i can filter only via  host tag not disk ?
you can try (show all except specific disk “diskname” on host “hostname”:
builtin:host.disk.usedPct:filter(or(not(in(“dt.entity.disk”,entitySelector(“type(disk),entityName.equals(~”/diskname~“)”))),not(in(“dt.entity.host”,entitySelector(“type(host),entityName.equals(~“hostname~”)”)))))::splitBy(“dt.entity.host”,“dt.entity.disk”)
btw, this is not DQL query, but classic metric query
yes i can exclude it by tagging disk and filter via disk tag . but is there any option available in “metric key” type events  with entity filter.  The reason why i am asking is by this classic query my "metric selector " events limits exceeded
if you are forced to use metric selector metric event, you can use dimension filter to exclude disk from event definition
yeah good idea. but dimention filter does have tag one . it required  exact name/id equal / not equal ones
there is a lot of limitations in metric key defined metric events..
