AK
1
Hello Folks,
I have requirement where we want to exclude one disk from monitoring for particular host.
I tried to utilize the Preferences --> Disk options however, it doesn’t have any option to add particular host.
By any other way can we do it? Kindly suggest.
AK
Hi @AK , good day.
You can find this option in the specific host you want to exclude the disk monitoring, Exclude disks and network traffic from host monitoring — Dynatrace Docs
- In the Dynatrace menu, go to Hosts and select the host for which you want to create a disk exclusion rule.
- On the host overview page, select
- > Settings.
- Select Disk options.
Try and let us know.
AK
3
@dannemca, I got the same information from chat support as well.
Thanks for your prompt response on this
Do you know what happen in you have a global custom disk rule?
Which is going to have preference?
Best regards
