Disable Alert to exclude specific NFS for many servers.
Hi Team!
We have a farm of Linux and AIX Servers mounted by NFS Server. We know we can exclude disks, however, this requires you to set it on every server at DynaPortal. Any method to set this for a Group or All UNIX servers?
Thanks, Mauricio
Currently the only way to this without doing it one by one on each server, is to ensure the applicable hosts are part of the same host grouping. From there you can set the disk exclusion rule at just the host group level and it will apply to all the entities in that host group:
Your only other option at this time is to set the exclusion at the environment level from the UI Settings page which will apply to all your hosts.
I found the same menu item in Settings --> Disk Options, is this new? does this take preference / apply to all mount points?
in the screenshot are these wildcard attributes sufficient?
The purpose is to exclude NFS alert globally and keep the monitoring.
The option you are talking about will disable the monitoring of the NFS.
Dynatrace still doesn’t provide a solution for this issue.
Hello There,
We have to set up the option over HostGroups perspective to cover up our necessity.
In our case we have to exclude some disks on AIX.
We have to fulfill the “MountPoint” and “FileSystem” type and it works properly.
Best Regards,
Carlos
