Custom disk-detection rules: exclude a filesystem
Dear All,
I have to exclude a filesystem. Therefore, I need to know about the following questions:
  • Will the below rule exclude/not exclude the filesystem from the monitoring?
  • Why do we have an alert and sample limit for the excluded filesystem?
Babar
@Babar_Qayyum Looking at what you have set up I hope this clarifies the function.
Alerting on: Low Disk Space
Alert if Disk Space is lower than: 3%
Alert if Disk Space is lower than 3% in: 8 samples within a 10min period
This Alert detection Criteria Applies to Host Disk names that: Start with ‘/patrol’
This Alert detection Criteria Applies to Host Disk names as defined above that also have hosts that include tags: <NONE>
As a result, you will only be alerting on Disks that start with ‘/patrol’ while ignoring everything else for this rule.
