Dear All,
Can we disable alerting for a disk or filesystem "the file system is available on a couple of thousands of hosts" globally instead of the host group and a specific host?
Babar
Dear All,
Babar
Yes, it is in Settings > Preferences > Disk options
Or playing with Custom disk-detection rules
Best regards
Hello @AntonPineiro
Oops! Totally overlooked. Thank you for pointing me out to the Settings > Preferences > Disk options.
Babar
You are welcome!
Best regards
