Does Dynatrace OneAgent captures disk types i.e. NFS vs EXT2, etc
Hello, can anyone please share your experience on handling NFS vs EXT2, etc file system alerting.
In our environments we use many file systems  and our observation is inodes kind of run out a lot in NFS then other types of file system. We have a dedicated team that supports NFS related tasks and we would like to route the alerts to that team. Current Custom Alerts don’t provide us the control to pick and choose the file system for alerting. I am wondering how are you handling these type of issues? Appreciate any suggestions!
Raj
Hi Raj,
Dynatrace will see NFS disk if it’s actually mounted on the server you’re monitoring.  Hopefully this helps.
Regards
You could also look into the disk analytics extension:
You can go to the settings of the host and check as shown below:
@bradley_danyo thank you for your recommendation. Will look into the details, we have quite a few mount points to monitor and alert.
