Display in Smartscape
Hello everyone
After we arrived in excellent condition including filters and tags we want to try using the Smartscape area
The question is
We can’t find the search lines here (the picture here is from one guide or another)
How can we add?
And How can you arrange the map here according to the tags we already have and we work with them in the dashboard + notifications
Hey Yuval,
The smartscape, along with other classic apps such as classic dashboards and classic problems, can be filtered by management zones which you can find in the top right under the funnel icon as shown in the image below.
Management zones can use tags that you have set up for filtering allowing for easy environment wide filtering. More information on creating them can be found in the docs linked below.
@Fin_Ubels approach is the correct one, as the management zone can be used not only for filtering but to create proper alerting profiles which is the starting point for your notifications.
Thanks for the quick answer,
I use different areas for example a lab environment, and a production environment
But each of the environments has a tag for a certain service, so I can put a tag here in the display and see the service related to that tag
