Hi, I have an on-premise docker swarm cluster monitored by Dynatrace. I need to gather network metrics from the containers. I know nettracer metrics should be available if we have this option enabled (host level):
But they are not. What do I do wrong? (agent has a proper version)
Is it following supported platforms?
Best regards
Yes, it might be the reason. Thank you
You are welcome. Maybe that is reason. Anyway, if you are using kernel 4.15 or higher, I would try to restart OneAgent or host or both. Just in case.
Best regards
I also have this problem, but in this case the server meets the requirements:
