Hello
I am setting up Dynatrace to monitor 3 docker containers running on a VM.
So the steps Ive done till now are to run the command on my docker host.
docker run -d --restart=unless-stopped --privileged=true --pid=host --net=host --ipc=host -v /:/mnt/root -e ONEAGENT_INSTALLER_SCRIPT_URL="https://<URL_TO_MY_DYNATRACE_INSTANCE>/e/bf04f8bb-444b-41b2-a0fb-1b58f3123a68/api/v1/deployment/installer/agent/unix/default/latest?Api-Token=XbPpcnr9TnyQqqFppJhgO&arch=x86&flavor=default" dynatrace/oneagent:1.22.1000 APP_LOG_CONTENT_ACCESS=1
I even used the latest image.
The 3 containers running are Tomcat, Nginx and MySQL.
The problem I am getting is that the services Tomcat and Nginx are not being monitored and Im getting the Warning “This process must be restarted”
Ive done a docker-compose restart as well as manually restarting the docker containers but the Warning does not go away. Even restarted the VM.
I even downloaded a generic tomcat docker image from DockerHub, ran that and that too is giving the same Warning.
Im not sure what Ive missed ? What would be the best way to troubleshoot this ?
I even stopped the docker container and installed OneAgent via script but the issue is the same.
