I’m a little confused by the documentation below. For 2.0 extensions it states the below. To me this is saying it is needed otherwise the extension will not work, but that is not the case. I’ve created a JMX extension and added it to a bunch of hosts. I have not added the certificate but we are getting data from the extension. Can someone please clarify this?
Each host running your extension, whether OneAgent or ActiveGate, needs to have the root certificate saved in a dedicated directory. This extra step is required to enhance the security of the Extensions 2.0 framework.
