What is the correct way to handle Root and Developer certificates for signing Dynatrace extensions?
Hi all,
What is the correct way to handle Root and Developer certificates for signing Dynatrace extensions? if more than 2 developers are working on the extensions.
Generate the developer certificates as leaf certificates of the root certificate. Place the public root certificate on the ActiveGate/OneAgent (and upload it to Dynatrace). If a developer does something that requires a revoke, you don’t have to revoke the whole root certificate, you only have to mark the developer leaf certificate in the certificate revocation list.
Thank you, Mike!
