Dynatrace Extension Signature validation failed
Dynatrace Extension Signature validation failed error while uploading extension.
We are using internal certificate generation tool manage the life cycle of Certificate. To sign extension, we created certificate in pfx format and then used openssl command to separate cacert and private key file. Post that we used command “dt extension generate-developer-pem”  to fuse both cacert and key file. Same fused file used during bundle process and cacert was uploaded to vault.
Did you uploaded the certificate to the ActiveGate or oneagent?
