Extension Signature is Not Valid" - Issue with Dynatrace Extension 2.0 Upload
Hi all,
I’m encountering an issue while uploading a Dynatrace Extension 2.0 bundle, receiving the error: “Extension signature is not valid.”
Steps taken so far:
1.I’ve placed the certification file in the Active Gate path:
/var/lib/dynatrace/remotepluginmodule/agent/conf/certificates/​
2.Extension 2.0 is enabled on the Active Gate.
3. I have also used the appropriate sign commands during the bundle build process.
1.dt-sdk build --extra-platform manylinux_2_17_x86_64
2.dt extension assemble --src C:\Users\280380\vcleq\extension
3.dt extension sign --key secrets/developer.pem​
Has anyone faced a similar challenge or can suggest a way to resolve this issue? Any guidance would be greatly appreciated!
Thanks in advance!
Hi @kpurimitla ,
Have you added the root certificate to the Dynatrace credential vault? It’s necessary to sign an extension.
Here is the whole documentation about sign extensions.
Hope it helps.
Elena.
Thanks, Elena,
I don’t know how I forgot to add the certificate in the credential vault. Thank you so much for pointing that out! Now I’m able to upload the extension successfully.
Thanks again!
