Download extension 2.0
(I thought this was possible in the past?)
You can upload extensions
But is there a way to download extensions?
KR Henk
@joe
Hi Henk, you have to try it from web (https://www.dynatrace.com/hub/) and there it is in release notes (it’s not possible from dyna gui).
On top of grabbing it from the public hub, you can also download them using the API (you need to set a specific Accept header): Extensions 2.0 API - GET an extension — Dynatrace Docs
hi @henk_stobbe ,
after download the extension extract it then extract extension.zip then navigate to extension/lib/ directory you’ll find .whl file named with the same name of the extension like the below figure
to decrypt it just install wheel library
pip install wheel
then run this command with the file name as the below code
wheel unpack .\ibm_mq-3.5.10-py3-none-any.whl
BR,
Mostafa Hussein.
Just a note, you don’t need to install wheel, any zip extractor can extract those files (7zip, winrar, etc)
Thanks @david_lopes.
