Extension 2.0 examples
I am creating my own extension by following the help pages: WMI tutorial - extension package — Dynatrace Docs
I am wondering if we can use existing extensions as example.
You can download the yaml of any extension on the Dynatrace hub and use that as an example. If you go to the MSMQ tile for example (it’s quite small so easy to understand) you’ll be able to download the latest one under “Versions”.
Mike
Thanks, I didn’t saw that before.
Good to know :+1: thank you
Is it still possible to download the YAML, as I can’t see anywhere to do that now.
@RobWildridge1 you need to download the extension, unpack the zip file and unpack the extension.zip file (it’s a zip in a zip).
