DQL: How can I convert row values to column headings
I have some DQL that looks at a web servers log files and counts the number of hits on services gives me data in a table like this:
service_name status_code hit_count
checkOut 200 1234
checkOut 404 1
I would prefer to present it like this so that I can apply percentage calculations and categorise the record as being OK or needing action.
service_name 200 404
checkOut 1234 1
Is there a way to do this kind of thing?
Unfortunately the only technique I know to get it is via same method you probably saw already:
https://community.dynatrace.com/t5/DQL/DQL-How-to-Flatten-an-Array/m-p/251125/highlight/true#M1073
For your data it would look like:
data
  record(serviceName="checkOut", status_code=200, hit_count=1234),
  record(serviceName="checkOut", status_code=404, hit_count=1),
  record(serviceName="login", status_code=200, hit_count=4),
  record(serviceName="login", status_code=403, hit_count=1)
| summarize { d=collectArray(array(toString(status_code),hit_count)) }, by: {serviceName}
| fieldsAdd d=toString(d)
| parse d, "'[' KVP{ '[' DQS:key ', ' LONG:value ']' ', '?}:code ']'"
| fieldsFlatten code
| fieldsRemove d, code
Kris
Thanks Kris, you are right I did read the other thread.   This approach does work fine and is actually quite similar to how I would have approached in in SPL which is where my skillset is coming from.
