Good afternoon, how can I extract the entries from this column and convert each entry into rows?
I need to extract the information from each entry and create a row for each of those entries.
thanks
Hey Carlos,
You will want to do add a ‘expand’:
| expand array
I believe you can use the “expand” command to flatten the array and parse out the data using JSON object naming convention.
data record(value = "[{\"hello\" : \"world\"}]")
| parse value, "JSON_ARRAY:greeting"
| fields greeting
| expand greeting
| fieldsAdd greeting=greeting[hello]
thanks
