πŸ“Œ TIP#1: Extracting values from a JSON_ARRAY using DQL
When analyzing logs or business events that include structured payloads, it’s common to receive data in the form of a JSON_ARRAY. If your field contains this format (for example, under rs.body_result), you can extract specific values from each object in the array.
Here’s a real-world example, where the array contains market data objects with fields like symbol, currency and broadcast_time:
  { "symbol": "BNA6C", "currency": "EXT", "closing_price": 103, "broadcast_time": "91844" },
  { "symbol": "BNA6X", "currency": "ARS", "closing_price": 107000, "broadcast_time": "91847" },
  { "symbol": "BN2M6", "currency": "ARS", "closing_price": 0.01, "broadcast_time": "91847" },
  { "symbol": "BU4J6", "currency": "ARS", "closing_price": 101.1, "broadcast_time": "91843" }
To extract all broadcast_time values and get the array size, use the following DQL:
| parse rs.body_result, """JSON_ARRAY:parsed_json_elements"""
| fieldsAdd array(parsed_json_elements[][broadcast_time]), alias: array.broadcast_time
| fieldsAdd arraySize(parsed_json_elements), alias: array.broadcast_time_count
:bullseye: Use Case: Finding the latest broadcast time
If your goal is to identify the most recent broadcast (i.e., the highest broadcast_time), simply add:
| fieldsAdd arrayMax(array.broadcast_time), alias: array.broadcast_time_max
This gives you the highest value inside the broadcast_time array.
:test_tube: Real Example Output (Notebook)
After running the full query in a Dynatrace Notebook, the result looks like this:
  • array.broadcast_time: [[β€œ91840”], [β€œ91834”], [β€œ91838”], [β€œ91821”], [β€œ91842”], [β€œ91841”], [β€œ132548”], [β€œ151414”], [β€œ91822”], [β€œ91843”], [β€œ91841”], [β€œ91842”], [β€œ165520”], [β€œ91843”], [β€œ91842”], [β€œ91820”], [β€œ91824”], [β€œ91820”], [β€œ91821”], [β€œ91820”], [β€œ91843”], [β€œ91840”], [β€œ91841”], [β€œ91829”], [β€œ91845”], [β€œ91815”], [β€œ91845”], [β€œ91829”], [β€œ163735”]]
  • array.broadcast_time_count: 29
  • array.broadcast_time_max: 165520
:blue_book: Notes:
  • This method works on any JSON_ARRAY-compatible field in logs or business events.
  • You can replace broadcast_time with any other field (like symbol, currency, etc.).
  • Useful in financial feeds, external API logs, or payload inspection scenarios where the structure is consistent but the array length varies.
Hope this helps streamline your JSON parsing in Dynatrace!
Nice! Thank you! :money_mouth_face:
Thanks for sharing πŸ™
