keekos
March 23, 2023, 2:17pm
1
I’m having trouble extracting array attributes when there isn’t a top level name for the array.
For example, given the following json request body payload:
[{"Account":"f2fafaf3a","Name":"John Doe","MediumID":"a9fjah"}]
How do I extract the value for Account or Name in the Business Analytics capture rules? The documentation here doesn’t seem to cover this use case.
https://www.dynatrace.com/support/help/platform-modules/business-analytics/ba-events-capturing#report-business-event-oneagent
Are you using DQL Array ?
Best regards
isidre
April 4, 2023, 7:27am
3
An example of capturing a JSON with nested array (with a JSON element inside of it in position 0):
"id2": "json_with_array_json_nested",
"accountData":
"Account": "f2fafaf3a",
"Name": "John Doe",
"MediumID": "a9fjah"
Path to capture account name:
accountData.0.Account
This works to get the first position of the array “0” and the value inside the nested JSON. This works on single value arrays.
keekos
April 4, 2023, 8:05pm
4
Thanks, that unfortunately doesn’t cover the use case when your data sample omits accountData key for the array.
I ended up using DQL parse and was able to retrieve the correct value.
PARSE(requestbody, "DATA 'Account'LD SPACE?':' SPACE? DQS:Account ")
isidre
April 5, 2023, 4:10pm
5
Ok, so the request body is an array containing a single JSON. Understood.
A processing rule works fine then. great!
Linked here from our good friend @KlausEnzenhofer - with a second question for ya: what about extracting an array into a bizevent field?
"accountData":
"Name": "John Doe",
"Account": "gkahfkgjnv",
"Name": "Andreas Grabner",
"MediumID": "03u6n9"
"Account": "5j2nngov8bn",
"Name": "Brian Wilson",
"MediumID": "03u5nvov94n"
And I wanted to grab just the Name and MediumID fields.
Using this matcher: $.accountData.[Name,MediumID] would return an array and not a string.
Would we need to just JSONParse() that field then similar to the DPL above?
@victoria has a similar question: https://community.dynatrace.com/t5/Open-Q-A/How-to-Get-Specific-Properties-from-All-Elements-in-an-Array/m-p/257621#M34001
Yeah my only specific concern is that I do not want to capture the entire complex object into the biz event since some of it contains sensitive information. So I do not even want it to get to the point where I can parse it with DQL.
