When running the same query in the data explorer and in DQL, DQL one misses some data points. Is this normal? Is there a way to fix it?
Thanks in advance!
No, it should not happen. Are those timeframes the same? Set the resolution to 1 minute on both (in Data Explorer, you have auto).
However, you should not miss any datapoint from “continuous” metrics such as process cpu usage.
@elenaperez please open a support ticket.
