When diagnosing RUM problems, knowing the structure of dtCookie might come handy. In the documentation, we can see:
Some are more intuitive than others.
In the following URL, @henk_stobbe shows that we have remove the 3A in app:
https://community.dynatrace.com/t5/Dynatrace-tips/how-to-reverse-engineer-a-dtCookie-so-you-can-see-what-placed/m-p/182943
But other keys are more cryptic, including srv & sn. And others I have found no reference, like rcs-3Acss
Anyone got more info on this that can be shared?
the cryptic cookie structure… I always cringe when i have to break it all down. let me see if one of my RUM contacts can break it down for us.
@AntonioSousa the ‘sn’ and the values after it, is it possible that the string is the host ID or even the process/service ID that is supporting the call/injection?
@ChadTurner,
As a cookie, it wouldn’t make much sense to be based on host & processes and even services. They all change quite frequently, while dtCookie seems to be pretty stable. It does support several applications though, so I suspect it keeps growing.
And then there’s the length. The sn has 32 chars, while the host/processes & services have IDs with 16 chars. I have tried finding 16 char blocks, but with no success.
It would be more correct to match it to a User ID, but those are 45 chars long, although I suspect the first 13 digits are a timestamp. So, it’s also 32 chars. I did a quick comparison with a session I know is mine, but they didn’t match. Looking at the sn, it seems purely hexadecimal, while the User ID might be a Base64 encoding. Did a quick test, but it did not yield any conclusion…
hmm, good job looking into those possible justifications. I reached out to a RUM person asking what all that means. Haven’t heard back, ill hit up another rum expert that I have in my contacts.
