Hi all,
Recently i have tried to do develop a python based Extension (V2.0).
I am using VSCode DT integration extension with the extension SDK.
Using the documentation regarding the SDK we managed to developed a working extension that meets our requirements.
The extension contains an activation schema part , which is the user configuration form where he can configure and enter details for extended customization.
Using various extension found on the HUB and many examples from the internet, i almost found everything i needed, except for the following:
inside my endpoint, i want to define a textbox like property. the goal is to allow the user to paste a text which i want to use inside the server as a script.
for example :
i have defined a property whose type is “text”, referenced enums, referenced objects and more.
but i could not find any extension/example regarding create a textbox/textarea of some sort.
And i have been told it is possible, but without a definite answer.
Thank you for you help !
