I can find info on the extension.yaml file, but very little about activationSchema.json… Given how important this file seems to be, I would think this has to be documented somewhere, right?
The most I found was on the dt-extensions-python-sdk page and it confuses me greatly. It seems to insinuate that the Create command of the python-sdk will generate the Activation Schema file automatically. However, I’m looking at the rabbitMQ Python extension’s ActivationSchema.json file and I see things defined in it that I have a hard time believing were filled out automatically based on data it has collected from the script. Not to mention that there is a python method for getting the contents of the activationSchema.json file, so how can the activationSchema.json file be automatically generated based on script contents if the script needs to get data from the file itself?
We need documentation that details the following:
- Are the activationSchema.json file contents completely automated, or are we supposed to be configuring it?
- What do the fields in this file do and what are all of the possible values for each field?
- And, most importantly, why would we use a field? This is something that is missing from a lot of Dynatrace’s documentation (not all, some sections are pretty good). Meaning that, even when they explain what something is, I still have no clue what it does or why I would use it (for example, fastCheck… The only place I’ve seen it explained is in the context of the SNMP extension, but I see it used in Python extensions and I don’t know how or why to use it…).
We are about one week before the end of EF1 and we still not have a proper documentation for EF2…
The only solution is to contact support each time we have a question.
@pahofmann can you give me the link of the Unix remote extension you talk ? Thanks
So on our side, we cannot migrate to EF2.
We will try to stay on EF1 without any support : now when we contact Dynatrace support on EF1 issue, the only answer we get is “migrate to EF2 Extension”.
Hi. Is there at least a schema file somewhere for the activationSchema.json file? I want to know what the possible fields and values are that can be used there (yes, I can look at other extensions’ activationSchema files, but that still doesn’t give me a complete picture, nor does it give me a real explanation of what and why something is used).
I’ve looked in the /v2/extensions/schema api endpoint and there doesn’t appear to be a schema file that explains the activationSchema.json file.
I’m looking back at some of the documentation for the old EF1.0 and it is pretty fantastic. Is there any plan to get that level of detail for the 2.0 framework? It’s been a while and still nothing. But honestly, I’ll just take a schema file for that activationSchema.json file at this point… Just… something…
Hi Mike. Any word on this yet? It’s been almost a year (and extensions 2.0 has been around for several more years prior to that) and we still don’t have proper documentation (that I can find) on the activationSchema.json file…
Sure, looking at other extensions can help, but ultimately we need to know what should/can be in there and how to use it to write good python extensions. Currently, we’re all just kind of winging it.
Using the vsCode extension can help because it will show some auto-complete, but that still isn’t the same as seeing the whole schema at once to get an understanding of how it all works and ties together.
While documentation would be nice, I’d settle for just the schema file at this point…
I’m really struggling here and could use some documentation to exlpain what these fields do and what’s possible with the ActivationSchema.json file.
Finding various examples with other existing extensions and examining their json file is tedious and doesn’t really show what is possible.
And, to be fair, this issue is not limited to just that file. A similar issue with the extensions.yaml file. For example, I recently discovered the wmi extension can run WMI WQL queries and return the results as Logs instead of just metrics. This isn’t documented anywhere. I just happened to find it on a community post and it is used in the MS Exchange extension. But without that post, I would have probably never found it.
My point is, how many other useful features and capabilities are there that we don’t know about because of the absence of documentation listing all of the possible fields, parameters, and descriptions of the ActivationSchema.json and extensions.yaml files?
There is currently a rework going on for the extension documentation. I’ll raise to the team that they need to consider the activation schema as part of that rework as it’s very complicated to write Python extensions without documentation.
Maybe make the activationSchema.json schema definition file publicly available? It’s not as good as actual documentation, but it would at least be something we can use in the meantime until the documentation is ready. As I said in a previous reply in this thread, I see this URL in many of the activationSchema.json files, but the URL is not publicly available:
When defining elements in the ActivationSchema.json file, there is a “type” property. Most of the time, I just see things like “object”, “list”, and “text” defined in there, but what are all the other possible types?
I sometimes see a “subtype” property defined for certain elements. One example of a subtype I saw had a value of “url”. Again, what are all the possible subtypes and when/why would I use them?
Sometimes I see a “constraints” property defined. What are all the possible constraints and what does each constraint do?
One weird thing I see constraints used for sometimes is to define a “type” of “NOT_EMPTY”, which I find odd because for every element you can define a property of “nullable” and set it to either true or false. By setting “nullable” to true, wouldn’t that be the same as setting the “NOT_EMPTY” constraint? I don’t get the difference.
Looking at the ElasticSearch extension’s activationSchema.json file, I see some elements (like the “zone"filters” element) have a “metadata” property. Again, what are all the possible metadata properties and values we can set and when/why would we use them?
Those are just a verysmall sample of questions that I have.
On top of stuff like that, documenting the general layout of the file and how everything connects in that file would also help. Ideally, you guys would provide example file snippets along with screenshots of how those snippets’ settings affect the UI in the Monitoring Configuration.
Explaining is great, but showing while you explain is even better!
I’ve been asking for the schema to be made public, the challenge is that it’s our full settings 2.0 schema, and there would be so much in there that the expectation from our product management is that it’d create more questions than it’d solve. We’re hoping to add something into the vscode extension from my team to simplify it for everyone.
Those of us willing to dig through it will really appreciate the info. Those who aren’t willing are going to ask for help either way… As someone willing to dig in, I’d rather have too much info than none at all.
Yeah, I get it, but I gotta agree with Joseph_Hobbs. I’d rather have too much info than not enough.
Anyways, hopefully the example questions I provided above give you guys an idea of what we’re looking for and I am excited to see the improvements in vsCode as well.
