Hey,
The best documentation I’ve found is on this page:
I hope this helps. :wink:
Hey,
Hi Mike,
Any update on the extension doc progress, specifically around the Activation Schema?
Yes, they’ve had those docs for a while now. Unfortunately, they are not super helpful. They don’t have the data that is being asked for in this thread. Thanks though.
The best approach so far is to have a look at activationSchema for some existing extension that is available in the HUB.
There is no news. The rework is ongoing though so hopefully something will come. We spend quite some time trying things out in my team, so basing it off existing extensions is easiest still.
Yeah, still leaves a lot to be desired. Ideally, I’d like to see the schema for all of the available params and values.
Existing extensions are great but dissecting them and figuring out what and why they do the things they do is laborious and often incomplete.
For example:
How many different “type” and “subType” values are there? What are all the “type” and “subType” values? What do the various “subType” values do?
How does the “preCondition” object work? When can we use it and when can we not use it? Is there a “postCondition” object?
In the “uiCustomization” object, what are all the available objects and properties we can use there? Is it just “tabs”, or are there other customizations?
I could go on and on. Any time I work on a custom python extension, I find a dozen or more objects that I wonder about and then I wonder how many more helpful objects and properties there are that I don’t even know about…
My point being, without the schema, it’s very hard to know what is and isn’t possible and how to effectively use that page.
I understand the activationSchema.json file’s schema is part of a bigger schema doc and there is concern that sharing it could cause confusion, but I still feel like it should be released. The kind of people that would even bother wanting to look at it should be the kind of people that can pick through it and find what they need.
Or you guys can have an intern or junior associate pull out all of the activationSchema parts from the larger schema file and put it into its own document page and share that with us.
Extensions 2.0 has been out for a very long time at this point, and we still don’t have effective documentation. It can be very frustrating to work with.
Hi! Came here, hoping that there would be some answers to this. But apparently not.
Still not apparently. I guess we will never have this documentation.
But I don’t need it anymore, we are moving to Datadog.
Old reply, I know, but that’s not the documentation being asked for here.
It’s been a while. Any update on this whatsoever @Mike_L ?
I was replying to @MathieuB asking @pahofmann where the Unix remote extension is.
Ahh, my bad. Missed that.
@Mike_L any updates on thhis?
I mainly still use the documentation I shared a year ago.
It’s not perfect, but it’s the best publicly available option I’ve found so far. Combined with some reverse engineering of existing extensions, it lets me accomplish most of what I need.
There are not any updates. It’s on the product manager for the extensions framework, @V_e.
Are you able to get him / her to reply to this thread?
I’ve asked him.
