I am building docker image and AMI for active gate. I would like to preinstall the activegate. We would like to keep our environment immutable. But when we run it we would like to pass in env url and token to connect it to particular env. Is there a way to achieve it ?
We are providing ActiveGate container image that can be fetched from docker registry available on Dynatrace Cluster since 1.209. It’s been officially released with a limited scope functionalities, currently K8S monitoring, agent routing. Before you build & use custom image, I’d like to understand your use-case.
As for starting Activegate docker image, probably @Lukasz_Halman can help you here. Executing HTTP monitors can be still achieved without Synthetic Engine (only AG), but SE is required for Browser monitors, and as for now, it might not be easy to install and run SE within docker container.
