Hi guys.
Is it feasible to install Environment ActiveGates as containers?
I´m not referring to monitor a Kubernetes Cluster by installing a containerized ActiveGate as stated here (i.e.: as a Dynatrace Operator):
Get started with Kubernetes/OpenShift monitoring
but I´m referring to install an Environment ActiveGate acting as a classic ActiveGate installed on a VM:
- Routing OneAgents traffic (Collector)
- Monitor Cloud environments (AWS, Azure)
- Monitor remote technologies via Extensions (1.0 and 2.0)
- Run Synthetic monitors
if so, do I do it ?
And what about the admin tasks:
- Configuring the .properties Files
- Check ActiveGate logs
- Start/Restart the Services (dynatracegateway, remotepluginmodule)
- Upgrade the ActiveGate SW
- etc …
Thank you very much in advance.
Regards.
Hi @juanjo_garcia
First you need to understand which functionalities are supported by containerized AG from here
And then to decide if you what to Deploy ActiveGate in Kubernetes/OpenShift as a StatefulSet
HTH
Yos
Hi Yos.
Thank you very much for your help, the information you have provided is extremely useful.
Have you deployed any ActiveGates as Containers ? If so:
- Have you run into any issues ?
- Are the day-to-day admin tasks very different compared to ActiveGates installed on VMs ?
Regards.
Hello @juanjo_garcia
ActiveGate is updated automatically on pod restart whenever there is a new version available unless the image version is specified in cr.yaml. I am looking for the other information as well in case I can provide it.
Please have a look at the below link in case you did not go through yet.
Babar
Hi Babar.
Thank you very much for letting me know.
I´m concern about the admin tasks when it comes to ActiveGates as Containers. We are used to carry out them in an IaaS-classical-way neverthless with Kubernetes is different.
Regards.
Hi @juanjo_garcia
Did not install containerized AG with out dynatrace operator.
From documentation its look like there is no admin staff that you need to take care off, beside to restart the pod every time you need to upgrade the AG version.
Please pay attention to ActiveGate limit sizing hints
HTH
Yos
Hi Yos,
If I would like to collect OTLP metrics and traces from Kubernetes environment I should use a not containerized AG outside of the Kubernetes cluster?
Thanks in advance.
Best regards,
Mizső
Hi @Mizső
From documentation its look you are right and for OLTP ingest you will need host based AG
HTH
Yos
Hi Yos,
Thanks for your swift response.
I hope it will be changed sooner or later.
Have a nice day.
Best regards,
Mizső
we installed the AG as a container specifically to use as ENVIRONMENT AG on AWS. As per the first links, this is not supported and the issue basically is the following.
The AG contacts the metadata service (Use instance metadata to manage your EC2 instance - Amazon Elastic Compute Cloud) to get its credentials. I was not able to get the AG to use the provided credentials in the environment variables (as is standard with EKS and ServiceAccounts)
Support sent me over here to request the feature
