Hi @radek_jasinski ,
yes, that is all the information when i execute describe command. the below is the log for that activegate pod. Can you please check this.
@radek_jasinski wrote:
Hi @saisandeep
Is that all the information you have in the log?
I don’t see anything indicative of an error here.
Radek
sandeep@master:~$ sudo kubectl logs petlinic-activegate-0 -n dynatrace
Defaulted container "activegate" out of: activegate, certificate-loader (init)
Copy configuration templates to /var/lib/dynatrace/gateway/config
Assigned id = 0x49b1c08e
Setting environment AG token
Applying default config
Enabling selected features: MSGrouter,kubernetes_monitoring,restInterface
Setting dns entry point to https://{environmentid}.live.dynatrace.com/communication;-1], [https://{environmentid}.live.dynatrace.com/communication;-1], [https://{environmentid}.live.dynatrace.com/communication;-1], [https://{environmentid}.live.dynatrace.com/communication;-1], [https://{environmentid}.live.dynatrace.com/communication;-1], [https://{environmentid}.live.dynatrace.com/communication;-1], [https://{environmentid}.live.dynatrace.com/communication;-1], [https://{environmentid}.live.dynatrace.com:443/communication;-1]],
System: startupTimestamp = 1687354006981, osInfo = Platform: Linux, Version: 5.4.0-150-generic, Architecture: amd64, Processors: 1, jvmInfo = VM: OpenJDK 64-Bit Server VM, Version: 11.0.18, Vendor: Eclipse Adoptium, Memory [maxMemory=759M, initHeap=384M, maxHeap=759M, usedMeta=14M, committedMeta=15M, totalPhysicalMemory=1536M, freePhysicalMemory=1407M], buildVersion = 1.267.43.20230512-112635
EntityType: COLLECTOR, isRunningInContainer = true
2023-06-21 13:27:32 UTC INFO [<jkr36399>] [<com.compuware.apm.debug.beaconforwarder>, BeaconForwarderService] Beacon Forwarder disabled. Skipping initialization of UEM Configuration Poller and synthetic results reporter.
2023-06-21 13:27:32 UTC INFO [<jkr36399>] [HttpClientServiceImpl] No proxy server configured.
2023-06-21 13:27:32 UTC INFO [<jkr36399>] [<collector>, CollectorLifeCycle] Collector Operation State = 'STARTUP_CONNECTING'
2023-06-21 13:27:32 UTC INFO [<jkr36399>] [<collector.services>, ServicesManager] State changed from 'STARTUP_INIT' to 'STARTUP_CONNECTING'
2023-06-21 13:27:32 UTC INFO [<jkr36399>] [<collector.services>, ServicesManager] Initializing services..
2023-06-21 13:27:32 UTC INFO [<jkr36399>] [GenericFileCacheModuleImpl] Generic filecache service initialized.
2023-06-21 13:27:32 UTC INFO [<jkr36399>] [<collector.comm>, LocalSupportArchiveService] LocalSupportArchive service initialized.
2023-06-21 13:27:32 UTC INFO [<jkr36399>] [GenericIngestModule] Generic ingest service initialized.
2023-06-21 13:27:32 UTC INFO [<jkr36399>] [<collector.services>, ServicesManager] Registering message handlers...
2023-06-21 13:27:32 UTC INFO [<jkr36399>] [<collector.modules>, ModulesManager] State changed from 'STARTUP_INIT' to 'STARTUP_CONNECTING'
2023-06-21 13:27:32 UTC INFO [<jkr36399>] [<collector.modules>, ModulesManager] Registering message handlers...
2023-06-21 13:27:32 UTC INFO [<jkr36399>] [<collector.modules>, ModulesManager] Initializing modules..
2023-06-21 13:27:32 UTC INFO [<jkr36399>] [<collector.modules>, ModulesManager] kubernetes_monitoring module is ready.
2023-06-21 13:27:32 UTC INFO [<jkr36399>] [OdinModule] Odin module initialized.
2023-06-21 13:27:32 UTC INFO [<jkr36399>] [<collector.modules>, ModulesManager] odin_collector module is ready.
2023-06-21 13:27:32 UTC INFO [<jkr36399>] [RunningStateController] state: ACTIVE_GATE=false,BEACON_FORWARDER_WAIT=false,BEACON_FORWARDER_READY=false,MODULES=true,operationState='STARTUP_CONNECTING'
2023-06-21 13:27:32 UTC INFO [<jkr36399>] [<collector.core>, CollectorSelfMonitoringPoller] stop Collector Self Monitoring Poller
2023-06-21 13:27:32 UTC INFO [<jkr36399>] [<collector.core>, SelfMonitoringPeriodicSender] stop Collector Self Monitoring periodic sender
2023-06-21 13:27:32 UTC INFO [<jkr36399>] [<collector.core>, CollectorRuntimeImpl] Collector started successfully.
2023-06-21 13:27:32 UTC DEBUG [<jkr36399>] [<collector.core>, LogStatisticsWriter] Stats for the last: 0 seconds. Local time: 2023-06-21 13:27:32 GMT. Threads: 82. Active agents: 0. Memory usage in kB: free memory: 319,348; heap: 384,704; max heap: 777,920; direct byte buffers: 8.
Network statistics:
outgoingHttpErrors: 0; incomingHttpErrors: 0
Queue length: server Id: -999; OneWay: 0; Request: 0. Selfmonitoring: enabled: true; metrics sent: 0.
2023-06-21 13:27:33 UTC INFO [<jkr36399>] [HttpClientServiceImpl] No proxy server configured.
2023-06-21 13:27:34 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] request: sender=COLLECTOR(id=0x0000000049b1c08e), target=ANY_SERVER(id=0x0000000000000000), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=2
2023-06-21 13:27:34 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] response: sender=ANY_SERVER(id=0x0000000000000000), target=COLLECTOR(id=0x0000000049b1c08e), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=2, error COMMUNICATION_ERROR, reason=java.net.UnknownHostException: sg-us-east-1-52-55-57-17-prod-us-east-6-virginia.live.dynatrace.com source=ANY_SERVER 0x0000000000000000
2023-06-21 13:27:34 UTC WARNING [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] Initial collector setup received with error:COMMUNICATION_ERROR, reason=java.net.UnknownHostException: sg-us-east-1-52-55-57-17-prod-us-east-6-virginia.live.dynatrace.com source=ANY_SERVER 0x0000000000000000 [Suppressing further messages for 1 hour]
2023-06-21 13:27:35 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] request: sender=COLLECTOR(id=0x0000000049b1c08e), target=ANY_SERVER(id=0x0000000000000000), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=3
2023-06-21 13:27:35 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] response: sender=ANY_SERVER(id=0x0000000000000000), target=COLLECTOR(id=0x0000000049b1c08e), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=3, error COMMUNICATION_ERROR, reason=java.net.UnknownHostException: sg-us-east-1-34-237-88-136-prod-us-east-6-virginia.live.dynatrace.com source=ANY_SERVER 0x0000000000000000
2023-06-21 13:27:36 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] request: sender=COLLECTOR(id=0x0000000049b1c08e), target=ANY_SERVER(id=0x0000000000000000), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=4
2023-06-21 13:27:36 UTC WARNING [<jkr36399>] [<collector.core>, CommunicationLayer] Collector starts failover mode
2023-06-21 13:27:36 UTC INFO [<jkr36399>] [<collector>, CollectorLifeCycle] Collector Operation State = 'FAILOVER'
2023-06-21 13:27:36 UTC INFO [<jkr36399>] [<collector.services>, ServicesManager] State changed from 'STARTUP_CONNECTING' to 'FAILOVER'
2023-06-21 13:27:36 UTC INFO [<jkr36399>] [<collector.modules>, ModulesManager] State changed from 'STARTUP_CONNECTING' to 'FAILOVER'
2023-06-21 13:27:36 UTC INFO [<jkr36399>] [<collector.core>, Identification] Stop identification messages thread
2023-06-21 13:27:36 UTC INFO [<jkr36399>] [<collector.comm>, ClusterRuntimeInfoPoller] stop cluster runtime info poller
2023-06-21 13:27:36 UTC INFO [<jkr36399>] [<collector.comm>, ClusterTimePoller] stop cluster time poller
2023-06-21 13:27:36 UTC INFO [<jkr36399>] [<collector.core>, ConfigurationPoller] stop configuration poller
2023-06-21 13:27:36 UTC INFO [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] start initial collector setup poller in failover mode
2023-06-21 13:27:36 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] request: sender=COLLECTOR(id=0x0000000049b1c08e), target=SERVER(id=-999), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=5
2023-06-21 13:27:36 UTC WARNING [<jkr36399>] [<collector.core>, CommunicationLayer] Collector started failover mode
2023-06-21 13:27:36 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] response: sender=SERVER(id=-999), target=COLLECTOR(id=0x0000000049b1c08e), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=5, error COMMUNICATION_ERROR, reason=java.net.UnknownHostException: sg-us-east-1-52-4-253-12-prod-us-east-6-virginia.live.dynatrace.com source=SERVER -999
2023-06-21 13:27:36 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] response: sender=ANY_SERVER(id=0x0000000000000000), target=COLLECTOR(id=0x0000000049b1c08e), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=4, error COMMUNICATION_ERROR, reason=java.net.UnknownHostException: sg-us-east-1-34-236-11-154-prod-us-east-6-virginia.live.dynatrace.com source=ANY_SERVER 0x0000000000000000
2023-06-21 13:27:37 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] request: sender=COLLECTOR(id=0x0000000049b1c08e), target=SERVER(id=-1000), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=6
2023-06-21 13:27:37 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] response: sender=SERVER(id=-1000), target=COLLECTOR(id=0x0000000049b1c08e), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=6, error COMMUNICATION_ERROR, reason=java.net.UnknownHostException: sg-us-east-1-35-171-243-226-prod-us-east-6-virginia.live.dynatrace.com source=SERVER -1000
2023-06-21 13:27:38 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] request: sender=COLLECTOR(id=0x0000000049b1c08e), target=SERVER(id=-1001), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=7
2023-06-21 13:27:38 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] response: sender=SERVER(id=-1001), target=COLLECTOR(id=0x0000000049b1c08e), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=7, error COMMUNICATION_ERROR, reason=java.net.UnknownHostException: sg-us-east-1-52-55-57-17-prod-us-east-6-virginia.live.dynatrace.com source=SERVER -1001
2023-06-21 13:27:39 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] request: sender=COLLECTOR(id=0x0000000049b1c08e), target=SERVER(id=-1002), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=8
2023-06-21 13:27:39 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] response: sender=SERVER(id=-1002), target=COLLECTOR(id=0x0000000049b1c08e), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=8, error COMMUNICATION_ERROR, reason=java.net.UnknownHostException: sg-us-east-1-34-237-88-136-prod-us-east-6-virginia.live.dynatrace.com source=SERVER -1002
2023-06-21 13:27:40 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] request: sender=COLLECTOR(id=0x0000000049b1c08e), target=SERVER(id=-1003), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=9
2023-06-21 13:27:40 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] response: sender=SERVER(id=-1003), target=COLLECTOR(id=0x0000000049b1c08e), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=9, error COMMUNICATION_ERROR, reason=java.net.UnknownHostException: sg-us-east-1-34-237-88-136-prod-us-east-6-virginia.live.dynatrace.com source=SERVER -1003
2023-06-21 13:27:41 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] request: sender=COLLECTOR(id=0x0000000049b1c08e), target=SERVER(id=-1004), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=10
2023-06-21 13:27:41 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] response: sender=SERVER(id=-1004), target=COLLECTOR(id=0x0000000049b1c08e), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=10, error COMMUNICATION_ERROR, reason=java.net.UnknownHostException: jkr36399.live.dynatrace.com source=SERVER -1004
2023-06-21 13:27:42 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] request: sender=COLLECTOR(id=0x0000000049b1c08e), target=SERVER(id=-1005), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=11
2023-06-21 13:28:02 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] response: sender=SERVER(id=-1005), target=COLLECTOR(id=0x0000000049b1c08e), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=11, error COMMUNICATION_ERROR, reason=java.net.UnknownHostException: sg-us-east-1-52-55-57-17-prod-us-east-6-virginia.live.dynatrace.com: System error source=SERVER -1005
2023-06-21 13:28:03 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] request: sender=COLLECTOR(id=0x0000000049b1c08e), target=SERVER(id=-1006), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=12
2023-06-21 13:28:03 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] response: sender=SERVER(id=-1006), target=COLLECTOR(id=0x0000000049b1c08e), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=12, error COMMUNICATION_ERROR, reason=java.net.UnknownHostException: sg-us-east-1-52-55-57-17-prod-us-east-6-virginia.live.dynatrace.com source=SERVER -1006
2023-06-21 13:28:04 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] request: sender=COLLECTOR(id=0x0000000049b1c08e), target=SERVER(id=-1007), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=13
2023-06-21 13:28:24 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] response: sender=SERVER(id=-1007), target=COLLECTOR(id=0x0000000049b1c08e), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=13, error COMMUNICATION_ERROR, reason=java.net.UnknownHostException: sg-us-east-1-3-220-98-230-prod-us-east-6-virginia.live.dynatrace.com: System error source=SERVER -1007
2023-06-21 13:28:25 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] request: sender=COLLECTOR(id=0x0000000049b1c08e), target=SERVER(id=-999), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=14
2023-06-21 13:28:45 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] response: sender=SERVER(id=-999), target=COLLECTOR(id=0x0000000049b1c08e), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=14, error COMMUNICATION_ERROR, reason=java.net.UnknownHostException: sg-us-east-1-52-4-253-12-prod-us-east-6-virginia.live.dynatrace.com: System error source=SERVER -999
2023-06-21 13:28:46 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] request: sender=COLLECTOR(id=0x0000000049b1c08e), target=SERVER(id=-1000), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=15
2023-06-21 13:29:06 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] response: sender=SERVER(id=-1000), target=COLLECTOR(id=0x0000000049b1c08e), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=15, error COMMUNICATION_ERROR, reason=java.net.UnknownHostException: sg-us-east-1-3-220-98-230-prod-us-east-6-virginia.live.dynatrace.com: System error source=SERVER -1000
2023-06-21 13:29:07 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] request: sender=COLLECTOR(id=0x0000000049b1c08e), target=SERVER(id=-1001), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=16
2023-06-21 13:29:07 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] response: sender=SERVER(id=-1001), target=COLLECTOR(id=0x0000000049b1c08e), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=16, error COMMUNICATION_ERROR, reason=java.net.UnknownHostException: sg-us-east-1-3-220-98-230-prod-us-east-6-virginia.live.dynatrace.com source=SERVER -1001
2023-06-21 13:29:08 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] request: sender=COLLECTOR(id=0x0000000049b1c08e), target=SERVER(id=-1002), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=17
2023-06-21 13:29:28 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] response: sender=SERVER(id=-1002), target=COLLECTOR(id=0x0000000049b1c08e), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=17, error COMMUNICATION_ERROR, reason=java.net.UnknownHostException: sg-us-east-1-34-236-11-154-prod-us-east-6-virginia.live.dynatrace.com: System error source=SERVER -1002
2023-06-21 13:29:29 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] request: sender=COLLECTOR(id=0x0000000049b1c08e), target=SERVER(id=-1003), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=18
2023-06-21 13:29:49 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] response: sender=SERVER(id=-1003), target=COLLECTOR(id=0x0000000049b1c08e), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=18, error COMMUNICATION_ERROR, reason=java.net.UnknownHostException: sg-us-east-1-35-171-243-226-prod-us-east-6-virginia.live.dynatrace.com: System error source=SERVER -1003
2023-06-21 13:29:50 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] request: sender=COLLECTOR(id=0x0000000049b1c08e), target=SERVER(id=-1004), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=19
2023-06-21 13:30:10 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] response: sender=SERVER(id=-1004), target=COLLECTOR(id=0x0000000049b1c08e), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=19, error COMMUNICATION_ERROR, reason=java.net.UnknownHostException: sg-us-east-1-52-4-253-12-prod-us-east-6-virginia.live.dynatrace.com: System error source=SERVER -1004
2023-06-21 13:30:11 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] request: sender=COLLECTOR(id=0x0000000049b1c08e), target=SERVER(id=-1005), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=20
2023-06-21 13:30:11 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] response: sender=SERVER(id=-1005), target=COLLECTOR(id=0x0000000049b1c08e), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=20, error COMMUNICATION_ERROR, reason=java.net.UnknownHostException: sg-us-east-1-3-220-98-230-prod-us-east-6-virginia.live.dynatrace.com source=SERVER -1005
2023-06-21 13:30:12 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] request: sender=COLLECTOR(id=0x0000000049b1c08e), target=SERVER(id=-1006), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=21
2023-06-21 13:30:32 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] response: sender=SERVER(id=-1006), target=COLLECTOR(id=0x0000000049b1c08e), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=21, error COMMUNICATION_ERROR, reason=java.net.UnknownHostException: sg-us-east-1-35-171-243-226-prod-us-east-6-virginia.live.dynatrace.com: System error source=SERVER -1006
2023-06-21 13:30:33 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] request: sender=COLLECTOR(id=0x0000000049b1c08e), target=SERVER(id=-1007), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=22
2023-06-21 13:30:53 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] response: sender=SERVER(id=-1007), target=COLLECTOR(id=0x0000000049b1c08e), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=22, error COMMUNICATION_ERROR, reason=java.net.UnknownHostException: sg-us-east-1-52-55-57-17-prod-us-east-6-virginia.live.dynatrace.com: System error source=SERVER -1007
2023-06-21 13:30:54 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] request: sender=COLLECTOR(id=0x0000000049b1c08e), target=SERVER(id=-999), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=23
2023-06-21 13:30:54 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] response: sender=SERVER(id=-999), target=COLLECTOR(id=0x0000000049b1c08e), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=23, error COMMUNICATION_ERROR, reason=java.net.UnknownHostException: sg-us-east-1-34-237-88-136-prod-us-east-6-virginia.live.dynatrace.com source=SERVER -999
2023-06-21 13:30:55 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] request: sender=COLLECTOR(id=0x0000000049b1c08e), target=SERVER(id=-1000), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=24
2023-06-21 13:31:15 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] response: sender=SERVER(id=-1000), target=COLLECTOR(id=0x0000000049b1c08e), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=24, error COMMUNICATION_ERROR, reason=java.net.UnknownHostException: sg-us-east-1-35-171-243-226-prod-us-east-6-virginia.live.dynatrace.com: System error source=SERVER -1000
2023-06-21 13:31:16 UTC DEBUG [<jkr36399>] [<collector.core>, InitialCollectorSetupPoller] request: sender=COLLECTOR(id=0x0000000049b1c08e), target=SERVER(id=-1001), content-type=INITIAL_COLLECTOR_SETUP, priority=NORMAL, message-id=25
