Dynatrace API Limit for Managed Environments
I have a question about the Dynatrace API. I know that there is a limit of 50 requests per minute. I would like to know if this limit applies to each API endpoint individually or to all environment APIs in total.
Is it possible to increase this limit? I ask because I want to export Dynatrace time series metrics and use them here.
I would like your advice and suggestions.
Thank you,
Hi, @Murat_Can! Have you managed to find the answer to your question? It would be great if you share it with the Community :slightly_smiling_face:
This documentation for Managed explains it in detail: Dynatrace API - Access limit — Dynatrace Managed Docs
