Dynatrace Application Security Monitoring vs vCenter VMware
On the perform there’s a presentation about Application Security Monitoring.
With this module is it possible to see security issue (CVE) from a vCenter VMware ?
Chris
Thats a very question. I would assume so but hopefully Dynatrace Reps will follow up on this and provide you an answer :slightly_smiling_face:
At the moment, only Java applications have security monitoring available. Should be more broad in the near future…
OK thank you
I report the question to our CSM.
I’ll update the post when I’ll have a answer
Hi Chris,
The currently supported technologies are Java, .NET, PHP, Node.js and Kubernetes, you can find more details in the docs: https://www.dynatrace.com/support/help/shortlink/start-security#supported-technologies
There is no support for CVEs from vCenter at this time.
